[GRASS-dev] Re: [GRASS GIS] #989: wx georectify: implement best features of i.points
GRASS GIS trac at osgeo.org
Thu Jul 15 05:25:01 EDT 2010
 Reporter:  hamish                |       Owner:  grass-dev@…
     Type:  enhancement           |      Status:  new
 Priority:  normal                |   Milestone:  6.5.0
Component:  wxGUI                 |     Version:  svn-develbranch6
 Keywords:  georectify i.rectify  |    Platform:  All
      Cpu:  All                   |
Comment(by mmetz):
 I am finfished with a wxGUI version of i.points, based on the
 georectifier. Some comments on the suggestions:
 Replying to [ticket:989 hamish]:
 > wishes from #728:
 >     * would it be possible to change the color of GCP lines which are 1
 standard dev. out from the mean GCP error as orange and 2 S.D. out as red?
 that is a nice way in i.points to see where your typos are. Or failing
 that, allow sort rows by clicking on column so you could group the worst
 offenders to the top.
 User can define factor for highlight threshold = mean + stddev * factor,
 alternatively only the point with the highest RMS error is highlighted.
 Additionally, columns can be sorted by clicking on the column head, works
 with all columns. First click sorts ascending, second click on same column
 head sorts descending.
 >     * more i.points goodness: can you change the color of the map marker
 to orange if that is the currently selected GCP data row? and have it
 still display on the map but turn to red if it the Use box is unticked?
 New coloring: separate colors for regular points, points with high RMS
 error, unused points, the currently selected point. Display of unused
 points can be disabled.
 >     * long shot wish: i.vpoints lets you select a vector map from the
 target mapset to overlay on the fly based on the current tansform
 calculation.
 Not sure how easy this is to do in the wxGUI, or more precisely, how to do
 this in the wxGUI.
 > The other nice thing it has is left and right panels, in the left one
 you click on a feature in the source image, and in the right you click on
 what you know to be the same point in another map (rast or vect) in the
 target location. It then uses the x,y from the left pane and the
 east,north from the right pane to create the GCP without having to know or
 type any coords.
 The left and right panels are now there. Clicking on source or target
 display already creates GCP coordinates in the Georectifier, also in the
 new GCP Manager. I have put in a third panel with the points list which is
 in the same frame on top of the source and target map display. The points
 list can be grabbed and dragged outside if desired (floating pane).
 New feature: you can adjust the target display to the current zoom of the
 source display and vice versa through the toolbar (Adjust display zoom),
 works once there are at least 3 halfway accurate GCPs.
 Replying to [comment:2 hamish]:
 > * the tool needs a help page.
 Now there for the new GCP mananger, plus a help button in the toolbar.
 Replying to [comment:3 hamish]:
 >  * it would be nice if it asked you "are you sure?" on exit:
 >  `[Save and exit] / [Abandon changes and exit] / [Cancel]`
 > very easy to lose half an hour's work by clicking the wrong button & no
 safety net.
 Done. Additional safety features are a confirmation message when setting
 GCP coords by clicking on a display (can happen accidentially), and a
 master copy of the POINTS file which is only updated if the user saves the
 points. I thought it necessary because points are saved to the POINTS file
 every time RMS is calculated, and I wanted a master copy as backup.
 `[Abandon changes and exit]` will overwrite the current POINTS file with
 the master copy, `[Save and exit]` will save the GCP list as you see it to
 the POINTS file.
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/989#comment:4>
