[GRASS-dev] g.transform overwrites POINTS file
Markus Metz markus.metz.giswork at googlemail.com
Fri Jul 16 03:38:33 EDT 2010
Why does g.transform overwrite the POINTS file [1]? This module is not
supposed to modify the POINTS file IIUC. It seems the coordinates of
the control points do not change. Not a serious issue, but if there is
no need to overwrite existing files, better don't do it?
Markus M
[1] https://trac.osgeo.org/grass/browser/grass/trunk/general/g.transform/main.c#L390
