[GRASS-dev] Re: [GRASS GIS] #1018: v.in.ogr.. Bad file descriptor: Files
GRASS GIS trac at osgeo.org
Mon Jul 19 17:45:26 EDT 2010
 Reporter:  MilenaN             |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  normal              |   Milestone:  6.4.0
Component:  wxGUI               |     Version:  6.4.0 RCs
 Keywords:  v.in.ogr, wingrass  |    Platform:  MSWindows 7
      Cpu:  x86-64              |
Comment(by hellik):
 Replying to [ticket:1018 MilenaN]:
 > Using RC6/wxgui import of shapefile fails:
 > v.in.ogr dsn=M:\MIWZP\dane_mi\Drogi_krajowe92_polyline.shp output=drogi
 > Projection of input dataset and current location appear to match
 > Layer: Drogi_krajowe92_polyline
 > Column name changed: 'DłUGOść_Z_' -> 'D3UGO_f_Z_'
 still valid?
 maybe you can supply a sample-shapefile containing non-ascii column names
 Helmut
 p.s. I've tried to add in the attribute table manager of a vector (dbf-
 table) a column named "UGOść".
   File "c:\Program
 Files\GRASS-64-SVN\etc\wxpython\gui_modules\dbm.py", line
 1683, in OnTableItemAdd
 index = list.InsertStringItem(sys.maxint, str(name))
 UnicodeEncodeError
 'ascii' codec can't encode characters in position 3-4:
 ordinal not in range(128)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1018#comment:1>
