[GRASS-dev] question about the concept 'window'
Peng Du
du at cs.utk.edu
Tue Jul 20 00:55:41 EDT 2010
Thanks Glynn. Now I have a much better picture of this.
Another question: is there any function similar to get_map_row(...) but
gets a column of data from raster image rather than a row?
Thanks,
Peng
On 7/18/2010 3:34 PM, Glynn Clements wrote:On 7/18/2010 3:34 PM, Glynn
Clements wrote:
> Peng Du wrote:
>> In function static int compute_window_row(int fd, int row, int *cellRow)
>> in ~/grass/7.0/grass_trunk/lib/raster/get_row.c, there is a check to see
>> if row is in window, and if not, 0 is returned.
>> I came across this function from get_map_row_nomask(...) in the same
>> file (which came all the way from Rast_get_row(fds[i], rowbuf, row,
>> maptype);), and the result of compute_window_row(...) is used to
>> determined whether to "read cell file row if not in memory".
>> I'm a little confused about the concept 'window' here, and how does that
>> relate to "in memory"?
> The "window", also referred to as the "region", defines a grid in
> cartographic space. It consists of a rectangle defined by the north,
> south, east and west bounds, and the number of rows and columns.
> All input raster maps are resampled, cropped and/or padded with nulls
> according to the window. This allows a module to read multiple raster
> maps which may have differing bounds and resolutions without having to
> handle the details explicitly.
>> My understanding is that "window" is a "visible area", and rows are only
>> read from disk file if it's within this "window" area. Then what would
>> happen if rast_get_row is used to get the exact same row in exact the
>> same map more than once? Does the second time NOT read the row from file
>> because the first time has put this row in memory? In this case the
>> requested row is copied from a inner buffer that was filled with the
>> data during the first time call?
> Correct.
> The file lib/raster/R.h defines the core data structures used by the
> raster library. R__.fileinfo points to an array of fileinfo
> structures, indexed by the map's file descriptor (this is the actual
> Unix file descriptor of the cell/fcell file).
> Within the fileinfo structure, the "data" field points to the data for
> the current row, after decompression but before resampling or
> conversion. The "cur_row" field contains the number of the row to
> which the data corresponds.
> get_map_row_nomask() (which all of the higher-level "get row"
> functions use) checks whether the row being requested is equal to the
> row which is stored; if it is, it doesnt' bother to read the row from
> disc again.
> If an input map has a larger (coarser) north-south resolution than the
> current region, adjacent rows within the current region will often map
> to the same row in the underlying map. By caching the most recent row
> in the fileinfo structure, redundant disc access is avoided.
> Note that the "processed" data cannot be cached, as it may depend upon
> a MASK map, which can have a finer resolution than the map itself.
> Also, it's permitted to change the window while a map is being read,
> and it's also permitted to change the requested format (CELL, FCELL or
> DCELL).
> If the processed data was cached, it would be necessary to store
> additional information about the cached data in order to determine
> whether it can be re-used. Storing the "raw" data from the file
> doesn't have these problems, as the only processing (the
> decompression) doesn't depend upon any parameters or settings.
> Correct.
> disc again.
> DCELL).
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100719/f7424fe8/attachment-0001.html
