[GRASS-dev] Re: [GRASS GIS] #1110: v.rast.stats locks up on wingrass
sonja
sonja.jankowfsky at cemagref.fr
Tue Jul 20 07:19:45 EDT 2010
GRASS GIS <trac <at> osgeo.org> writes:
> Reporter: hamish | Owner:
grass-dev@…
> Type: defect | Status: new
> Priority: normal | Milestone: 6.4.0
> Component: Vector | Version:
svn-releasebranch64
> Keywords: wingrass, v.rast.stats, v.db.addcol, v.info | Platform:
MSWindows XP
> Cpu: x86-32 |
> Comment(by hamish):
> Yvan wrote:
> This is the function and the message :
> (Mon Jul 19 15:12:58 2010)
> v.rast.stats vector=parcelles_masquees <at> mercier raster=mntyzeron_5m <at>
mercier
> colprefix=mnt
> C:/GRASS-64-SVN/scripts/v.rast.stats: line 268: v.db.addcol:
> command not found
> ERROR: Cannot continue (problem adding columns).
> (Mon Jul 19 15:13:06 2010) Command finished (7 sec)
> although I've only seen the subprocess freezing manifestation of this.
I get the same error using Grass 6.4 and 6.5.
Might this be related to the fact, that v.db.addcol is a shell script, the same
as v.rast.stats?
As far as I understand, while starting a shell script under windows, GRASS_SH
(which is set to sh.exe in the environment variables) will start the .bat file
in the /bin directory. This .bat file points to the shell script in the /scripts
directory.
However, once sh.exe started to read the shell script (here v.rast.stats), in
which directory will it search a second shell script referenced in the first
shell script (here v.db.addcol)? In the same?
Is there anything to fix this bug?
Thanks,
Sonja
