[GRASS-dev] Re: [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS
installer distribution
trac at osgeo.org
Tue Jul 20 10:56:55 EDT 2010
#820: r.in.wms doesn't work in WinGRASS installer distribution
Reporter: ddalimonte | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Packaging | Version: svn-releasebranch64
Keywords: r.in.wms, wingrass | Platform: MSWindows XP
Cpu: Unspecified |
Comment(by hamish):
trying again, 6.4.0svn nightly build r42845 on Windows XP using the NASA
wms global_mosaic example from above.
it dies because it can't find `$GISBASE/etc/r.in.wms/wms.request` even
though it is added to the PATH earlier on. (I note that everything else in
the path is /c/Program.. but the add-on etc/ dir is c:/Program... don't
know if that matters or not)
probably the Makefile needs to create .bat wrappers and copy them to
$GISBASE/bin/
I expect the same thing will be needed for i.oif which also keeps helper
shell scripts in $GISBASE/etc/.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:24>
