[GRASS-dev] timestamp problems with PG driver
Anne Ghisla a.ghisla at gmail.com
Tue Jul 20 11:02:29 EDT 2010
On Mon, Jul 19, 2010 at 3:25 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> I am connected to a PostgreSQL database with a timestamp column.
> While column type connection etc works there is a problem with the
> leading "0".
> The original timestamp
> 2010-03-26 05:31:25
> is printed by v.db.select as
> 2010-3-26 5:31:25
> Below an excerpt of debug output:
> D3/3: row = 99 nrows = 100
> D3/3: row 99, col 0, gpgtype 8, sqltype 6: val = '38.1958365'
> D3/3: row 99, col 1, gpgtype 8, sqltype 6: val = '15.9744719'
> D3/3: row 99, col 2, gpgtype 3, sqltype 3: val = '976451'
> D3/3: row 99, col 9, gpgtype 16, sqltype 11: val = '2010-03-26
> 05:31:25'  <<--- correctly fetched by PG driver
> D3/3: Row fetched
> D0/3: sqltype: 6
> D0/3: Fetched valuestring: 38.1958365
> D0/3: sqltype: 6
> D0/3: Fetched valuestring: 15.9744719
> D0/3: sqltype: 3
> D0/3: Fetched valuestring: 976451
> D0/3: sqltype: 6
> D0/3: sqltype: 3
> D0/3: sqltype: 3
> D0/3: sqltype: 6
> D0/3: sqltype: 3
> D0/3: sqltype: 3
> D0/3: sqltype: 11
> D0/3: Fetched valuestring: 2010-3-26 5:31:25    <---
> db_convert_column_value_to_string() failed
> 38.1958365|15.9744719|976451|||||||2010-3-26 5:31:25
> As far as I understand, the formatting is getting lost in
> lib/db/dbmi_base/columnfmt.c
> which calls
> db_get_column_value()
> Is a kind of internal string conversion needed to maintain the leading "0"?
> No clue...
As far as I understand C,
calls
lib/db/dbmi_base/valuefmt.c
db_convert_value_to_string()
that calls, in the datetime case:
lib/db/dbmi_base/datetime.c
db_convert_value_datetime_into_string()
I propose r42866 (trunk), backported to 6.5 and 6.4.
cheers!
anne
http://gis.fem-environment.eu/anne-ghisla/
