[GRASS-dev] Re: [GRASS GIS] #1018: v.in.ogr.. Bad file descriptor:
Files
trac at osgeo.org
Tue Jul 20 15:24:02 EDT 2010
#1018: v.in.ogr.. Bad file descriptor: Files
Reporter: MilenaN | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: v.in.ogr, wingrass | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:2 hamish]:
> the DBF format dates back to the early 1980s. It's not surprising that
it doesn't deal well with ascii chars >127. does it fail if you switch to
a more modern DB as the back-end? (db.connect)
The error is in the GUI, not the database code. Even if there are problems
with DBF and non-ASCII characters, it isn't getting that far.
Is the str() call actually necessary? I would have expected
`InsertStringItem` to accept a Unicode object.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1018#comment:3>
