[GRASS-dev] Re: Error building Grass6 devel branch on Ubuntu due to nviz
Markus Metz markus.metz.giswork at googlemail.com
Fri Jul 23 03:53:21 EDT 2010
Tim Michelsen wrote:
> Martin Landa:
>> Hi,
>> 2010/7/22 Moskovitz, Bob <Bob.Moskovitz at conservation.ca.gov>:
>>> I got the same error.  It would be great if I can get nviz to work
>>> again.  -Bob
>> as I have already mentioned in ML, wxnviz (wxGUI 3d view mode) is
>> still broken in GRASS 6.5 due to missing ctypes interface. Will be
>> fixed soon.
> OK, but why does it fail when builing the rest of GRASS?
> See my error log from make,please
Your error log from make:
Started compilation: Mi 21. Jul 23:49:43 CEST 2010
Errors in:
/usr/local/src/checkouts/grass/grass6_devel/gui/wxpython/nviz
In case of errors please change into the directory with error and run
'make'.
Your error log does not show any other errors, i.e. apart from wxnviz
the grass6 develbranch has been successfully compiled and is ready to
use. For nviz, you can use the tcltk nviz module.
Markus M
