[GRASS-dev] Rast_set_window() changes in 7.0
Helmut Kudrnovsky
hellik at web.de
Fri Jul 23 18:57:35 EDT 2010
some random testing in a self compiled wingrass7 (r42884) on WinVista32 with nc-sample-dataset:
general/g.region tested: ok
raster/r.compress tested: ok
raster/r.external tested: ok
raster/r.flow tested: ok
raster/r.horizon tested: ok
raster/r.in.arc tested: ok
raster/r.in.ascii tested: ok
raster/r.in.gdal tested: ok
raster/r.neighbors tested: ok
raster/r.slope.aspect tested: ok
"tested ok" means some arbitrary testing the modules with different resolutions.
but:
raster/r.resamp.bspline
r.resamp.bspline --verbose input=elevation at PERMANENT output=rresampbspline
spline step in ew direction 15
spline step in ns direction 15
Adjustiere OW Splines 146
Adjustiere NS Splines 147
loading input raster <elevation at PERMANENT>
initializing output
Unterregion 1 von 72.
Unterregion 2 von 72.
Schreibe Ausgabe...
ERROR: Output window changed while maps are open for write
and
raster/r.resamp.rst
r.resamp.rst input=elevation at PERMANENT ew_res=25 ns_res=25 elev=rrsz slope=rrsn aspect=rrsa pcurv=rrsv tcurv=rrsh mcurv=rrsm
Verarbeitung aller selektierten Ausgabedateien erfordert
7776000 Byte Plattenplatz für temporäre Dateien.
Verändere die Region temporär auf die gewünschte Auflösung...
ERROR: Input window changed while maps are open for read
best regards
Helmut
___________________________________________________________
GRATIS für alle WEB.DE Nutzer: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://movieflat.web.de
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20100724/51a05e02/smime.bin
