[GRASS-dev] [GRASS GIS] #1122: Command line hangs where dialog boxes work
GRASS GIS trac at osgeo.org
Wed Jul 28 12:33:27 EDT 2010
 Reporter:  JonBall      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  critical     |   Milestone:  6.4.0
Component:  default      |     Version:  6.4.0 RCs
 Keywords:               |    Platform:  MSWindows Vista
      Cpu:  Unspecified  |
 When trying to use the command line to test the fix of Ticket #809
 (http://trac.osgeo.org/grass/ticket/809#) , commands at the command line
 all appear to return the error "Bad file descriptor: Files" error.
 However, if you just type the command name without parameters you get a
 dialog box.  Using the dialog box to perform the exact same command
 results in no error.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1122>
