[GRASS-dev] v.krige and variogram preview
Markus Neteler
neteler at osgeo.org
Wed Jul 28 17:51:04 EDT 2010
announcement: as of r42926, you can install v.krige (with a few
limitations) in GRASS 6.4 from Addons via
g.extension v.krige
Anne and me backported the needed pieces of wxGUI which Martin
kindly reviewed.
So far so nice.
Still the following is open:
On Fri, Jun 25, 2010 at 3:26 PM, Anne Ghisla <a.ghisla at gmail.com> wrote:
> Hi devs,
> the split of v.krige into script and GUI broke the variogram preview -
> programmatically it was based on global variables, that worked when
> the code was all in one script.
> The point is that variogram preview needs to load data before hitting
> "Run" button. AFAIK, GRASS modules usually collect parameters and then
> run the appropriate command. I thought about creating a new module,
> v.krige.variogram, and call it from v.krige GUI only to draw the
> variogram and give the parameters back to v.krige. It could also be
> run separately.
> What do you think? Thanks in advance for suggestions.
Suggestions for Anne?
thanks
Markus
