Fwd: [GRASS-dev] GRASS on Windows Vista
Markus Neteler
neteler at osgeo.org
Sat Jul 31 13:10:10 EDT 2010
This should go to the list,
---------- Forwarded message ----------
Date: 2010/7/31
Subject: Re: [GRASS-dev] GRASS on Windows Vista
To: Markus Neteler <neteler at osgeo.org>
This version:
WinGRASS-6.4.SVN-r42933-1-Setup.exe
http://josef.fsv.cvut.cz/wingrass/grass64/WinGRASS-6.4.SVN-r42933-1-Setup.exe
2010/7/31 Markus Neteler <neteler at osgeo.org>
> 2010/7/31 Pavel Hnilica <pavel.hnilica at gmail.com>:
> > GRASS 6.4SVN with MSYS is not running on Windows Vista:
> Where di you get it (which version)?
> > _________________________________________________________________________________________________
> > Cleaning up temporary files ...
> > Starting GRASS ...
> > UPOZORNĚNÍ: Attention!
> > UPOZORNĚNÍ: Locking is not supported on Windows!
> > __________ ___ __________ _______________
> > / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
> > / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
> > / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
> > \____/_/ |_/_/ |_/____/____/ \____/___//____/
> > Welcome to GRASS 6.4.0svn (2010)
> > GRASS homepage: http://grass.osgeo.org/
> > This version running thru: Bourne Shell (/bin/sh)
> > Help is available with the command: g.manual -i
> > See the licence terms with: g.version -c
> > If required, restart the GUI with: g.gui wxpython
> > When ready to quit enter: exit
> > GRASS 6.4> Traceback (most recent call last):
> > File "c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py", line 1834, in
> > <module>
> > sys.exit(main())
> > File "c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py", line 1827, in
> > main
> > app = GMApp(workspaceFile)
> > File "c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py", line 1752, in
> > __init__
> > wx.App.__init__(self, False)
> > File
> > "C:\OSGeo4W\apps\Python25\lib\site-packages\wx-2.8-msw-unicode\wx\_core.py",
> > line 7935, in __init__
> > self._BootstrapApp()
> > File
> > line 7509, in _BootstrapApp
> > return _core_.PyApp__BootstrapApp(*args, **kwargs)
> > File "c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py", line 1770, in
> > OnInit
> > workspace = self.workspaceFile)
> > File "c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py", line 192, in
> > __init__
> > self.NewDisplay(show=False)
> > File "c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py", line 1248, in
> > NewDisplay
> > auimgr=self._auimgr, showMapDisplay=show)
> > File "C:\Program
> > Files\GRASS-64-SVN\etc\wxpython\gui_modules\wxgui_utils.py", line 95, in
> > __init__
> > self.Map = render.Map() # instance of render.Map to be associated
> > with display
> > File "C:\Program Files\GRASS-64-SVN\etc\wxpython\gui_modules\render.py",
> > line 402, in __init__
> > self.projinfo = self.ProjInfo()
> > line 765, in ProjInfo
> > p = gcmd.Command(['g.proj', '-p'])
> > File "C:\Program Files\GRASS-64-SVN\etc\wxpython\gui_modules\gcmd.py",
> > line 369, in __init__
> > _("Error: ") + self.GetError()))
> > gui_modules.gcmd.CmdError
> > GRASS 6.4>
> > System report: Execution failed:'g.proj -p'
> Please try a recent nightly version here:
> The problem might be already fixed.
> Markus
