[GRASS-dev] RE: [GRASS-user] Question with Python-SWIG example [SEC=UNCLASSIFIED]
Markus Neteler neteler at osgeo.org
Tue Jun 1 06:33:16 EDT 2010
On Sun, May 16, 2010 at 6:50 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> I've already replaced the SWIG bindings in 7.0 with the ctypesgen
> version.
> Ideally, I'd like to do the same in 6.x in time for 6.4.0, so that we
> can forget that the SWIG version ever existed. The main issue there is
> the vdigit and nviz modules in the wxPython GUI (which don't work on
> Windows in any case). I haven't tried using ctypesgen for C++, though.
Is the ctypes usage in GRASS 7 now sufficiently implemented that a
backport to GRASS 6 could be started?
It would be sad to not see GRASS 6.4.0 published before the FOSS4G
conference in Barcelona in Sept 2010.
Markus
