[GRASS-dev] grass7 on mac OSX
Massimo Di Stefano massimodisasha at gmail.com
Tue Jun 1 17:36:58 EDT 2010
Now the error i means :
>>> In [2]: from grass.lib import raster
>>> Traceback (most recent call last):
>>> File "<ipython console>", line 1, in <module>
>>> ImportError: No module named lib
is reflected in the gui.
the new GUI code changes are affected by it,
tring to build grass70, starting the application
i have a broken gui that show me this error log :
GRASS 7.0.svn (spearfish60):~ >
WARNING: Vector digitizer is not available (dlopen(/Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/vdigit/_grass7_wxvdigit.so, 2): Symbol not found: __Py_RefTotal
  Referenced from: /Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/vdigit/_grass7_wxvdigit.so
  Expected in: flat namespace
 in /Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/vdigit/_grass7_wxvdigit.so).
Note that the vector digitizer is currently not working under MS Windows (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS.
  File "/Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py", line 87, in <module>
    import gui_modules.nviz_tools as nviz_tools
  File "/Users/Shared/source/grass_trunk/dist.i386-apple-darwin10.3.0/etc/gui/wxpython/gui_modules/nviz_tools.py", line 36, in <module>
    from nviz_mapdisp import wxUpdateView as wxUpdateView
  File "/Users/Shared/source/grass_trunk/dist.i386-apple-darwin10.3.0/etc/gui/wxpython/gui_modules/nviz_mapdisp.py", line 41, in <module>
    import wxnviz
  File "/Users/Shared/source/grass_trunk/dist.i386-apple-darwin10.3.0/etc/gui/wxpython/gui_modules/wxnviz.py", line 24, in <module>
    from grass.lib.grass import *
ImportError: No module named lib.grass
tring to re-run :  "g.gui" i have the same log.
just to check if my python "is bugged"
i build python2.6.5 source code,
in a non standard location "/usr/local/gislib/unix",
as unix library (no framework)
then i exported the path for the new python
and i used it to reconfigure-compile-install grass70,
but unluky i have problems to build wxpython
(i compiled wxwidjet as 32+64 bit but i'm having
problems  to built wxpython on it)
i'll try to figure out a wxpython cocoa build
and tell you if the grass.lib  not found problem persists.
thanks for any help.
Il giorno 27/mag/2010, alle ore 16.52, Michael Barton ha scritto:
> No ipython on the student's machine.
> I compiled GRASS 7 and had no problems. I posted my binary so others could use it. The one person who has tried it gets a bogus error about Python subprocess() not existing. The binary of GRASS 6.5 that I compiled and posted at the same time runs fine on her machine (demonstrating that subprocess() is OK).
> Oddly, some other folks here got similar bogus errors with GRASS 6.5 or 7 (I can't remember) when trying to run a Python script under winGRASS a few weeks back.
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On May 27, 2010, at 6:43 AM, William Kyngesburye wrote:
>> On May 27, 2010, at 3:56 AM, Massimo Di Stefano <massimodisasha at gmail.com
>>> wrote:
>>> Hell Soeren,
>>> seems i've an up-to-date revision :
>>> MacBook-Pro-15-di-Massimo-Di-Stefano:grass_trunk sasha$ svn up
>>> At revision 42358.
>>> i also did make distclean first to re-try configure && make.
>>> but your note about a "renamed" function, point me to a problem i
>>> had on qgis side too (make install overwrite the .app but ... it
>>> don't do it as aspected)
>>> infact, removing manually the old grass70.app (compiled from source)
>>> trashing the complete app from /Application , instead of overwrite
>>> it using "sudo make install"
>>> now i have :
>>> In [1]: import os, sys
>> I wonder if ipython is affecting this?  Just a random idea. (I can't
>> try anything right now- dev Mac died)
>>> the error is present but changes ... this time maybe can be a wrong
>>> sintax i used ???
>>> weird .. i'm a bit confused ;-)
>>> i'm tring to replicate, from command line, the code :
>>> import os, sys
>>> from grass.lib import grass, raster
>>> from ctypes import *
>>> input = sys.argv[1]
>>> grass.G_gisinit(sys.argv[0])
>>> mapset = grass.G_find_raster2(input, "")
>>> print mapset
>>> Massimo
>>> Il giorno 27/mag/2010, alle ore 10.37, Soeren Gebbert ha scritto:
>>>> Hello Massimo,
>>>> can you please make a svn update?The gmath function
>>>> G_math_backward_solving has been renamed into
>>>> G_math_backward_substitution a while ago. Maybe something got mixed
>>>> up?
>>>> Best
>>>> Soeren
