[GRASS-dev] grass7 on mac OSX
Massimo Di Stefano
massimodisasha at gmail.com
Tue Jun 1 20:34:25 EDT 2010
I succesfull build wxpython on snow leopard to be 32+64 bit against wx2.9 (svn version) <- is the only way to have wx with no "bitwise" problems on osx
then i installed ctypesgen
tring to build grass70 i got the error in wxpython gui code
re-running make inside its directory the error is not fixed.
i suppose this is related to wx version (2.9) instead of (2.8)
so it shouldn't be a grass related problem ...
this is the log :
http://www.geofemengineering.it/data/grass_wxgui_log.txt
i wonder if it's possible to adapt grass-gui code to run under 2.9 too :-/
i'm now recompiling ctypsegen on the system python to sede if it fix the grass.lib error
Il giorno 01/giu/2010, alle ore 23.53, Martin Landa ha scritto:
> Hi,
> 2010/6/1 Massimo Di Stefano <massimodisasha at gmail.com>:
>> Traceback (most recent call last):
>> File "/Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py", line 87, in <module>
>> import gui_modules.nviz_tools as nviz_tools
>> File "/Users/Shared/source/grass_trunk/dist.i386-apple-darwin10.3.0/etc/gui/wxpython/gui_modules/nviz_tools.py", line 36, in <module>
>> from nviz_mapdisp import wxUpdateView as wxUpdateView
>> File "/Users/Shared/source/grass_trunk/dist.i386-apple-darwin10.3.0/etc/gui/wxpython/gui_modules/nviz_mapdisp.py", line 41, in <module>
>> import wxnviz
>> File "/Users/Shared/source/grass_trunk/dist.i386-apple-darwin10.3.0/etc/gui/wxpython/gui_modules/wxnviz.py", line 24, in <module>
>> from grass.lib.grass import *
>> ImportError: No module named lib.grass
> ctypes grass.lib (lib/python/ctypes) is missing in your installation
> (ctypesgen required). wxGUI failure fixed in r42430.
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
