[GRASS-dev] grass7 on mac OSX
Wed Jun 2 04:41:30 EDT 2010
Massimo Di Stefano wrote:
> error in wx gui build (i'm using wx-cocoa)
> log :
> http://www.geofemengineering.it/data/grass_wxgui_log.txt
pseudodc.h: In member function ‘virtual void gpdcFloodFillOp::DrawToDC(wxDC*, bool)’:
pseudodc.h:210: error: invalid conversion from ‘int’ to ‘wxFloodFillStyle’
pseudodc.h:210: error:   initializing argument 4 of ‘bool wxDC::FloodFill(wxCoord, wxCoord, const wxColour&, wxFloodFillStyle)’
These are caused by trying to use wxWidgets 2.9. GRASS requires
wxWidgets 2.8.
> while start grass in text mode, again  grass.lib is not avaiable as
> grass.python module
You'll need to provide the output from "make -C lib/python" if you
want help with this.
