[GRASS-dev] grass7 on mac OSX
Michael Barton c.michael.barton at gmail.com
Wed Jun 2 05:31:37 EDT 2010
Massimo,
I recommend uninstalling any Python except the system one and using the system Python only. It should work.
Michael Barton
On Jun 2, 2010, at 10:16 AM, Massimo Di Stefano wrote:
> Il giorno 02/giu/2010, alle ore 04.54, Glynn Clements ha scritto:
>> Barton Michael wrote:
>>> I just compiled GRASS 7 a couple days ago, before leaving for Spain. Wx
>>> digitizer and nviz don't compile.
>> The gui/wxpython/nviz directory is no longer built; it has been
>> superseded by gui/wxpython/gui_modules/wxnviz.py.
>> The ctypes/SWIG changes don't touch the vdigit module.
>>> Also others can't even open my
>>> binaries.
>>> Is there a new configure switch for ctypes?
>> No. I added a local copy of ctypesgen to the source tree, so there are
>> no external dependencies.
>> ctypes itself is part of the standard library in Python 2.5 and 2.6.
> This means that also on OSX we don't need to install external libraries beacouse WxPython, Ctype are included in the system Python
> and Ctypsgen is included in the Grass source  (hence i don't have to install it as suggested in the preciouse mails)
> At this point i'm without any clue on how to debug the grass7.0 problems on OSX.
> I tried installing a new version of Python but unlucky it fails to build the gui (maybe beacouse i'm using wx2.9, see my previouse mail)
> i tried to compile grass using python.framework this time,
> but seems it find only python2.61 (system python)
> i treid to change grass.sh script .. but without lucky
> so i chosed to build without .app generation
> the results is :
> error in wx gui build (i'm using wx-cocoa)
> log :
> http://www.geofemengineering.it/data/grass_wxgui_log.txt
> while start grass in text mode, again  grass.lib is not avaiable as grass.python module
> (i have tried with (installed manually from svn) and without ctypesgen (using the version included in grass))
> Have you any suggestion like
> "add a print statment in the source code file X at line Y "
> to try to see where the problem begins ?
>>> Are we supposed to no longer
>>> use the python switch?
>> --with-python should only be required for vdigit.
>> Glynn Clements <glynn at gclements.plus.com>
