[GRASS-dev] grass7 on mac OSX
Massimo Di Stefano massimodisasha at gmail.com
Thu Jun 3 03:38:21 EDT 2010
i opened an issue on :
http://code.google.com/p/ctypesgen/issues/detail?id=7
i hope what i wrote is correct, tell me if i need to change something.
i'll also try to send a mail to the pythonmac mailing list.
Il giorno 03/giu/2010, alle ore 07.05, Glynn Clements ha scritto:
> Massimo Di Stefano wrote:
>> i applied the patch and tried to rebuild (after make distclean)
>>  File "/Users/Shared/source/grass_trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py", line 60, in __new__
>>    value = value[1:-1].decode('string_escape')
>> ValueError: invalid \x escape
> This looks like an issue with Apple's "C" headers being incompatible
> with anything other than Apple's version of gcc.
> I think that it's going to need someone with a Mac to investigate the
> issues and make the necessary changes to ctypesgen to either support
> Apple's "enhanced" C dialect, or to provide the necessary switches to
> disable the enhancements (if such switches exist).
> Glynn Clements <glynn at gclements.plus.com>
