[GRASS-dev] grass7 on mac OSX
William Kyngesburye
woklist at kyngchaos.com
Sat Jun 5 11:02:22 EDT 2010
On Jun 5, 2010, at 1:15 AM, Glynn Clements wrote:
>> With, though I get that unknown architecture
>> error in nviz.py. The ctypesgen authors seem to be aware of and patch
>> OSX issues, but maybe they never tried it with system framework headers.
> But does this prevent the generation of the wrapper?
>> There are more similar CF_INLINE definitions earlier, but they are
>> inside a #ifdef CF_INLINE.
> But do these prevent the wrapper from being generated, or result in it
> missing necessary definitions?
> ctypesgen ignores errors from the preprocessor (it doesn't capture
> stderr and doesn't care about the exit code). Errors only matter
> insofar as they cause significant declarations to be omitted or
> malformed.
> The ValueError is different as that's an exception being raised within
> ctypesgen itself; r42484 should deal with that.
Ah, it's generated.
Next error, after that finishes:
sed \
-e '/^# End loader$/a\
from ctypes_preamble import *\
from ctypes_preamble import _variadic_function\
from ctypes_loader import *' \
-e '/^# Begin preamble$/,/^# End preamble$/d' \
-e '/^# Begin loader$/,/^# End loader$/d' \
date.py > /Users/Shared/src/GRASS/svn/trunk/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/date.py
sed: 1: "/^# End loader$/afrom c ...": command a expects \ followed by text
make[2]: *** [/Users/Shared/src/GRASS/svn/trunk/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/date.py] Error 1
There is only 1 file after this in dist/etc/python/grass/lib: an empty date.py.
I never had any luck on OSX with newlines in sed replacement strings in makefiles. It'll work in shell scripts but not makefiles.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
