[GRASS-dev] Re: [GRASS-user] pdf maps
Glynn Clements
glynn at gclements.plus.com
Sun Jun 6 03:33:25 EDT 2010
Mohammed Rashad wrote:
> Is there any module in grass to read maps which are in PDF format to raster or vector.
> ArcGIS can read pdf files as raster maps. may i know the module is available in GRASS or GRASS-Addons repo.
Ghostscript can generate SVG output. I don't know of any tool to
import SVG directly, but Inkscape can convert SVG to DXF, which OGR
can handle. However, I don't know how much information will be lost in
the conversion.
Generating rasters is more straightfoward; Ghostscript can generate a
large number of raster formats, many of which can be imported using
e.g. r.in.gdal.
grass-user mailing list
grass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user
