[GRASS-dev] Re: [GRASS GIS] #1086: set_browser
Maris Nartiss
maris.gis at gmail.com
Tue Jun 8 12:08:48 EDT 2010
current trunk's grass.py HTML browser setup code is using wrong
approach on Linux and Windows.
If GRASS_HTML_BROWSER is unset:
On Linux it should at first check for presence of xdg-open command
from Portland project [1] and only in case of Portland absence start
"Guess the browser" game. xdg-open will use user's preffered browser;
Similar on Windows, it should use "explorer" as default. No guessing
required. [2]
Maris.
1. http://portland.freedesktop.org/wiki/
2. http://trac.osgeo.org/grass/ticket/980
2010/6/8, GRASS GIS <trac at osgeo.org>:
> #1086: set_browser
> Reporter: lucadelu | Owner: grass-dev at lists.osgeo.org
> Type: defect | Status: closed
> Priority: critical | Milestone: 7.0.0
> Component: Startup | Version: svn-trunk
> Resolution: fixed | Keywords:
> Platform: Linux | Cpu: All
> Changes (by neteler):
> * status: new => closed
> * resolution: => fixed
> Comment:
> Patch applied, thanks.
> Ticket URL: <http://trac.osgeo.org/grass/ticket/1086#comment:1>
> GRASS GIS <http://grass.osgeo.org>
