[GRASS-dev] WinGrass65 + import gui_modules.nviz_tools as nviz_tools: ImportError
Helmut Kudrnovsky hellik at web.de
Sun Jun 13 17:04:12 EDT 2010
>-----Ursprüngliche Nachricht-----
>Von: Martin Landa
>Gesendet: 13.06.2010 15:13:12
>An: Glynn Clements
>Betreff: Re: [GRASS-dev] WinGrass65 + import gui_modules.nviz_tools as  nviz_tools: ImportError
>2010/6/6 Glynn Clements <glynn at gclements.plus.com>:
>>> I will revert r42490, because WinGrass7 (from the WinGrass-installer)
>>> seems to need versioned libgrass_*.7.0.svn.dll in C:\Program
>>> Files\GRASS-70-SVN\extralib for starting and unversioned
>>> libgrass_*.dll C:\Program Files\GRASS-70-SVN\lib for wxnviz. with
>>> r42490 WinGrass7 isn't starting, with reverted r42490 WinGrass7 is
>>> starting but wxnviz (3D view mode) isn't working.
>well, there is no reason why GRASS libs should be located in extralib
>directory (speaking about native installer). Changed in r42547, GRASS
>libs are moved to `lib` directory.
ok.
>> Should the ctypes wrappers be changed to use the versioned library
> >name?
>Probably yes, just to avoid having copy of unversioned library names.
I've built a Wingrass7 with r42547. libgrass_datetime is still missing. so using the versioned library
name seems to be needed?
Helmut
___________________________________________________________
WEB.DE DSL ab 19,99 Euro/Monat. Bis zu 150,- Euro Startguthaben und
50,- Euro Geldprämie inklusive! https://freundschaftswerbung.web.de
