[GRASS-dev] [GRASS GIS] #1090: Access is denied - r.statistics
trac at osgeo.org
Tue Jun 15 15:58:55 EDT 2010
Reporter: nkale | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Keywords: r.statistics access denied | Platform: MSWindows 7
Cpu: x86-32 |
Related to ticket #1038 - Running the following:
r.statistics --verbose base=HUC at PERMANENT cover=ag at PERMANENT method=sum
output=huc_ag
results in the following error:
Access is denied.
ERROR: o_sum: running r.stats command
Same results when attempting to run an average as well. The fix mentioned
in the other ticket (change security settings to full control for USER)
didn't work.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1090>
