[GRASS-dev] Re: [GRASS GIS] #46: NVIZ fly mode broken on 64bit
systems
trac at osgeo.org
Wed Jun 16 11:57:26 EDT 2010
#46: NVIZ fly mode broken on 64bit systems
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: NVIZ | Version: svn-trunk
Keywords: nviz | Platform: Unspecified
Cpu: Unspecified |
Comment(by kwasnicki):
looks like the problem is a float overflow in
togl_flythrough.c:this_time() function. changing the (float) casts to
(double) has fixed this on my 64bit slackware install.
diff attached... although not 100% sure if i created the diff patch
properly, but this is just a one line change so i'm sure the code
maintainer can replicate the necessary change if the diff doesn't work.
Ticket URL: <http://trac.osgeo.org/grass/ticket/46#comment:5>
