[GRASS-dev] [GRASS GIS] #1092: WinGrass + R's installation path in
%PATH%
trac at osgeo.org
Sat Jun 19 10:22:18 EDT 2010
#1092: WinGrass + R's installation path in %PATH%
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Packaging | Version: svn-releasebranch64
Keywords: wingrass, R | Platform: MSWindows Vista
Cpu: Unspecified |
I have installed the WinGrass64-installer and R 2.11.1 on my
WinVista32-box.
the wingrass-installer delivers a command line.
in the command line during a Grass-session you can change to the
installation folder of R
and then you are able to start R inside a Grass-session.
it would be nice to have the R's installation path in %PATH%, so you can
start R directly
in the WinGrass-delivered command line.
From the R-Windows-FAQ:
(http://cran.r-project.org/bin/windows/base/rw-FAQ.html#Does-R-use-the-
Registry_003f)
"Does R use the Registry?" => this would maybe a starting point
maybe something for 6.4.1?
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1092>
