[GRASS-dev] WinGrass65 + import gui_modules.nviz_tools as
nviz_tools: ImportError
Helmut Kudrnovsky
hellik at web.de
Sat Jun 19 18:38:21 EDT 2010
-----Ursprüngliche Nachricht-----
Von: Glynn Clements
Gesendet: 19.06.2010 22:15:04
An: Martin Landa
Betreff: Re: [GRASS-dev] WinGrass65 + import gui_modules.nviz_tools as nviz_tools: ImportError
Martin Landa wrote:
> >> "WARNING: Nviz extension (3D view mode) disabled. Reason: intl not found."
> > It's odd that this only occurs when loading libraries dynamically via
> > Python.
> > libintl is required by all GRASS modules; not only is it used directly
> > by G_gettext(), but * (which is included from
> > <grass/glocale.h>) defines printf() etc as macros which refer to
> > libintl_printf() etc.
> the installation constains only libint3 and libintl-8 dll libraries, see
> $ find /c/Program\ Files\ \(x86\)/GRASS-70-SVN/ -name libint*.dll
> /c/Program Files (x86)/GRASS-70-SVN/extralib/libintl-8.dll
> /c/Program Files (x86)/GRASS-70-SVN/extralib/libintl3.dll
> When compiling /lib/python/ against `lintl3` instead of `lintl`,
> grass.libs.grass can be imported, but its empty.
Check for any error/warning messages during creation.
some error messages from compiling:
mkdir -p /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/script
/bin/install -c -m 644 core.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/script/core.py
/bin/install -c -m 644 db.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/script/db.py
/bin/install -c -m 644 raster.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/script/raster.py
/bin/install -c -m 644 vector.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/script/vector.py
/bin/install -c -m 644 array.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/script/array.py
/bin/install -c -m 644 __init__.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/script/__init__.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/script/core.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/script/db.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/script/raster.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/script/vector.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/script/array.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/script/__init__.py
/bin/install -c -m 644 grass__init__.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/__init__.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/__init__.py
make -C ctypes || echo /c/osgeo4w/usr/src/grass_trunk/lib/python/ctypes >> /c/osgeo4w/usr/src/grass_trunk/error.log
make[4]: Entering directory `/c/osgeo4w/usr/src/grass_trunk/lib/python/ctypes'
make /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib
make[5]: Entering directory `/c/osgeo4w/usr/src/grass_trunk/lib/python/ctypes'
mkdir -p /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib
make[5]: Leaving directory `/c/osgeo4w/usr/src/grass_trunk/lib/python/ctypes'
make date.py grass.py raster.py gmath.py proj.py imagery.py vector.py display.py stats.py dbmi.py g3d.py arraystats.py cluster.py trans.py vedit.py ogsf.py nviz.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/date.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/grass.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/raster.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/gmath.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/proj.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/imagery.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/vector.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/display.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/stats.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/dbmi.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/g3d.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/arraystats.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/cluster.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/trans.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/vedit.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/ogsf.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/nviz.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/__init__.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/ctypes_preamble.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/ctypes_loader.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/date.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/grass.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/raster.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/gmath.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/proj.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/imagery.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/vector.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/display.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/stats.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/dbmi.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/g3d.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/arraystats.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/cluster.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/trans.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/vedit.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/ogsf.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/nviz.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/__init__.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/ctypes_preamble.pyc /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/ctypes_loader.pyc
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_datetime.7.0.svn -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/datetime.h /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/P_datetime.h -o date.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmpr5m9dp.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmpr5m9dp.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmpr5m9dp.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmpr5m9dp.h
Status: Processing description list.
Warning: Could not load library "intl". Okay, I'll try to load it at runtime instead.
Status: Writing to date.py.
Status: Wrapping complete.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_gis.7.0.svn -lintl -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/gis.h /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/gisdefs.h -o grass.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmpfdijo4.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmpfdijo4.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmpfdijo4.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmpfdijo4.h
Status: Writing to grass.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_raster.7.0.svn -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/raster.h /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/rasterdefs.h -o raster.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmpmty4cd.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmpmty4cd.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmpmty4cd.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmpmty4cd.h
Status: Writing to raster.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_gmath.7.0.svn -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/gmath.h -o gmath.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmpzigx2p.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmpzigx2p.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmpzigx2p.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmpzigx2p.h
Status: Writing to gmath.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_gproj.7.0.svn -I/c/OSGeo4W/include -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/gprojects.h -o proj.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmp41dxug.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD -Ic:/OSGeo4W/include "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmp41dxug.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmp41dxug.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmp41dxug.h
Status: Writing to proj.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_imagery.7.0.svn -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/imagery.h /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/imagedefs.h -o imagery.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmpeodofg.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmpeodofg.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmpeodofg.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmpeodofg.h
Status: Writing to imagery.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_vector.7.0.svn -lgrass_dig2.7.0.svn -lgrass_dgl.7.0.svn -lgrass_rtree.7.0.svn -lgrass_linkm.7.0.svn -lgrass_dbmiclient.7.0.svn -lgrass_dbmibase.7.0.svn -lgrass_btree2.7.0.svn -I/c/OSGeo4W/include -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/vector.h /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/vect/dig_structs.h /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/vect/dig_defines.h -o vector.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmpto4cqg.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD -Ic:/OSGeo4W/include "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmpto4cqg.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmpto4cqg.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmpto4cqg.h
Status: Writing to vector.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_display.7.0.svn -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/display.h -o display.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmp7lrtvm.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmp7lrtvm.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmp7lrtvm.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmp7lrtvm.h
Status: Writing to display.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_stats.7.0.svn -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/stats.h -o stats.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmpyy4y4m.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmpyy4y4m.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmpyy4y4m.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmpyy4y4m.h
Status: Writing to stats.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_dbmiclient.7.0.svn -lgrass_dbmibase.7.0.svn -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/dbmi.h -o dbmi.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmprisvgw.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmprisvgw.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmprisvgw.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmprisvgw.h
Status: Writing to dbmi.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_g3d.7.0.svn -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/G3d.h -o g3d.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmpu3c0ih.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmpu3c0ih.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmpu3c0ih.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmpu3c0ih.h
Status: Writing to g3d.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_arraystats.7.0.svn -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/arraystats.h -o arraystats.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmponqy9b.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmponqy9b.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmponqy9b.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmponqy9b.h
Status: Writing to arraystats.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_cluster.7.0.svn -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/cluster.h -o cluster.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmpet3ndw.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmpet3ndw.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmpet3ndw.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmpet3ndw.h
Status: Writing to cluster.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_trans.7.0.svn -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/transform.h -o trans.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmp8pxouu.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmp8pxouu.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmp8pxouu.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmp8pxouu.h
Status: Writing to trans.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_vedit.7.0.svn -I/c/OSGeo4W/include -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/vedit.h -o vedit.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmpmzbsfp.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD -Ic:/OSGeo4W/include "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmpmzbsfp.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmpmzbsfp.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmpmzbsfp.h
Status: Writing to vedit.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_ogsf.7.0.svn -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/ogsf_proto.h /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/gstypes.h /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/gsurf.h /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/kftypes.h /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/keyframe.h -o ogsf.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmpcuryuz.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmpcuryuz.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmpcuryuz.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmpcuryuz.h
Status: Writing to ogsf.py.
GISRC=/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/demolocation/.grassrc70 GISBASE=c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32 PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:$PATH" PYTHONPATH="c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python;$PYTHONPATH" PATH="/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/bin:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/lib:.:/c/mingw/bin:/usr/local/bin:/bin:/c/OSGeo4W/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem" LC_ALL=C ./ctypesgen.py --cpp "gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include" -lgrass_nviz.7.0.svn -lintl /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include/grass/nviz.h -o nviz.py
Status: Preprocessing c:\users\syringia\appdata\local\temp\tmpy2l_4f.h
Status: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:\users\syringia\appdata\local\temp\tmpy2l_4f.h
Error: gcc -E -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include -I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include: cc1.exe: c:\users\syringia\appdata\local\temp\tmpy2l_4f.h: Permission denied
Status: Parsing c:\users\syringia\appdata\local\temp\tmpy2l_4f.h
Status: Writing to nviz.py.
sed -f fix.sed date.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/date.py
sed -f fix.sed grass.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/grass.py
sed -f fix.sed raster.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/raster.py
sed -f fix.sed gmath.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/gmath.py
sed -f fix.sed proj.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/proj.py
sed -f fix.sed imagery.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/imagery.py
sed -f fix.sed vector.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/vector.py
sed -f fix.sed display.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/display.py
sed -f fix.sed stats.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/stats.py
sed -f fix.sed dbmi.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/dbmi.py
sed -f fix.sed g3d.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/g3d.py
sed -f fix.sed arraystats.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/arraystats.py
sed -f fix.sed cluster.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/cluster.py
sed -f fix.sed trans.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/trans.py
sed -f fix.sed vedit.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/vedit.py
sed -f fix.sed ogsf.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/ogsf.py
sed -f fix.sed nviz.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/nviz.py
sed -f fix.sed __init__.py > /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/__init__.py
/bin/install -c -m 644 preamble.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/ctypes_preamble.py
/bin/install -c -m 644 loader.py /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/ctypes_loader.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/date.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/grass.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/raster.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/gmath.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/proj.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/imagery.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/vector.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/display.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/stats.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/dbmi.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/g3d.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/arraystats.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/cluster.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/trans.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/vedit.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/ogsf.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/nviz.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/__init__.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/ctypes_preamble.py
python -m py_compile /c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/python/grass/lib/ctypes_loader.py
make[4]: Leaving directory `/c/osgeo4w/usr/src/grass_trunk/lib/python/ctypes'
make[3]: Leaving directory `/c/osgeo4w/usr/src/grass_trunk/lib/python'
Helmut
___________________________________________________________
WEB.DE DSL ab 19,99 Euro/Monat. Bis zu 150,- Euro Startguthaben und
50,- Euro Geldprämie inklusive! https://freundschaftswerbung.web.de
