[GRASS-dev] Georrectification error in WinGRASS6.4.0RC6
Markus Metz
markus.metz.giswork at googlemail.com
Thu Jun 24 10:08:32 EDT 2010
Back to ML:
I fixed that only 3 days ago in r42618, a previous version could show
the error you got.
Ah, and you might need to remove a line in .grasswx6, starting with georect
ok:
georect;symbol;color;0:0:255;width;2
bad:
georect;symbol;color;(0,0,255,255);width;2
note: no brakets (), only 3 numbers separated by :
António Rocha:
> Markus I cannot remember unfortunely. I will uninstall and intall exacly the
> latest and get back to you and the mailing list.
> Back in 30 minutes
> Antonio
> Markus Metz wrote:
>> António Rocha:
>>> Hi there
>>> I have installed the latest WinGRASS binary release
>> Are you using WinGRASS-6.4.SVN-r42618-1-Setup.exe or another version?
>>> and I tried to use the
>>> georrectify functionality but I got an error. Immediately after I select
>>> image from where to get the GCP's, the Define/manage GCPs panel appears
>>> and
>>> an empty Map Display and the following is printed in the command output:
>>> Traceback (most recent call last):
>>> File "C:/GRASS6/etc/wxpython/wxgui.py", line 368, in
>>> OnGeorectify
>>> georect.GeorectWizard(self)
>>> File "C:\GRASS6\etc\wxpython\gui_modules\georect.py", line
>>> 215, in __init__
>>> self.xy_mapdisp.toolbars['georect'].OnZoomMap(None)
>>> File "C:\GRASS6\etc\wxpython\gui_modules\toolbars.py",
>>> line 366, in OnZoomMap
>>> self.mapdisplay.MapWindow.ZoomToMap(layer=layer)
>>> File "C:\GRASS6\etc\wxpython\gui_modules\mapdisp.py", line
>>> 2383, in ZoomToMap
>>> self.UpdateMap()
>>> 811, in UpdateMap
>>> self.parent.gismanager.georectifying.DrawGCP(coordtype)
>>> 886, in DrawGCP
>>> wxCol = wx.Colour(col[0], col[1], col[2], 255)
>>> File "C:\GRASS6\Python25\lib\site-packages\wx-2.8-msw-
>>> unicode\wx\_gdi.py", line 114, in __init__
>>> _gdi_.Colour_swiginit(self,_gdi_.new_Colour(*args,
>>> **kwargs))
>>> TypeError
>>> in method 'new_Colour', expected argument 1 of type 'byte'
>>> can it be some problem of my GRASS installation or is it a global issue?
>>> Thanks
>>> Antonio
>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>> signature
>>> database 5224 (20100624) __________
>>> The message was checked by ESET NOD32 Antivirus.
>>> http://www.eset.com
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> signature database 5225 (20100624) __________
>> http://www.eset.com
> __________ Information from ESET NOD32 Antivirus, version of virus signature
> http://www.eset.com
