[GRASS-dev] Georrectification error in WinGRASS6.4.0RC6
Markus Metz markus.metz.giswork at googlemail.com
Thu Jun 24 12:58:50 EDT 2010
António Rocha:
> My Source version, in OSGEO4W, is from 2 weeks ago and my binary it would be
> from also 2 weeks.
> I have just downloaded r42618 and it's getting that error.
> So I changed that file and now I don't get that error but only the source
> location is displayed. The other is still blank... IS that expected?
Yes, any maps to be displayed for the target location must be added
through the regular GIS layer manager and will be displayed in the
main (or currently active) display.
> Markus Metz wrote:
>> Back to ML:
>> I fixed that only 3 days ago in r42618, a previous version could show
>> the error you got.
>> Ah, and you might need to remove a line in .grasswx6, starting with
>> georect
>> ok:
>> georect;symbol;color;0:0:255;width;2
>> bad:
>> georect;symbol;color;(0,0,255,255);width;2
>> note: no brakets (), only 3 numbers separated by :
>> António Rocha:
>>> Markus I cannot remember unfortunely. I will uninstall and intall exacly
>>> the
>>> latest and get back to you and the mailing list.
>>> Back in 30 minutes
>>> Antonio
>>> Markus Metz wrote:
>>>> António Rocha:
>>>>> Hi there
>>>>> I have installed the latest WinGRASS binary release
>>>> Are you using WinGRASS-6.4.SVN-r42618-1-Setup.exe or another version?
>>>>> and I tried to use the
>>>>> georrectify functionality but I got an error. Immediately after I
>>>>> select
>>>>> image from where to get the GCP's, the Define/manage GCPs panel appears
>>>>> and
>>>>> an empty Map Display and the following is printed in the command
>>>>> output:
>>>>> Traceback (most recent call last):
>>>>>  File "C:/GRASS6/etc/wxpython/wxgui.py", line 368, in
>>>>> OnGeorectify
>>>>> georect.GeorectWizard(self)
>>>>>  File "C:\GRASS6\etc\wxpython\gui_modules\georect.py", line
>>>>> 215, in __init__
>>>>> self.xy_mapdisp.toolbars['georect'].OnZoomMap(None)
>>>>>  File "C:\GRASS6\etc\wxpython\gui_modules\toolbars.py",
>>>>> line 366, in OnZoomMap
>>>>> self.mapdisplay.MapWindow.ZoomToMap(layer=layer)
>>>>>  File "C:\GRASS6\etc\wxpython\gui_modules\mapdisp.py", line
>>>>> 2383, in ZoomToMap
>>>>> self.UpdateMap()
>>>>> 811, in UpdateMap
>>>>> self.parent.gismanager.georectifying.DrawGCP(coordtype)
>>>>> 886, in DrawGCP
>>>>> wxCol = wx.Colour(col[0], col[1], col[2], 255)
>>>>>  File "C:\GRASS6\Python25\lib\site-packages\wx-2.8-msw-
>>>>> unicode\wx\_gdi.py", line 114, in __init__
>>>>> _gdi_.Colour_swiginit(self,_gdi_.new_Colour(*args,
>>>>> **kwargs))
>>>>> TypeError
>>>>> in method 'new_Colour', expected argument 1 of type 'byte'
>>>>> can it be some problem of my GRASS installation or is it a global
>>>>> issue?
>>>>> Thanks
>>>>> Antonio
>>>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>>>> signature
>>>>> database 5224 (20100624) __________
>>>>> The message was checked by ESET NOD32 Antivirus.
>>>>> http://www.eset.com
>>>>> _______________________________________________
>>>>> grass-dev mailing list
>>>>> grass-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>>>> signature database 5225 (20100624) __________
>>>> http://www.eset.com
>>> signature
>>> http://www.eset.com
>> http://www.eset.com
> __________ Information from ESET NOD32 Antivirus, version of virus signature
> http://www.eset.com
