[GRASS-dev] Segmentation fault i.smap
Tue Jun 29 23:26:41 EDT 2010
Markus Neteler wrote:
> The "only" thing to do seems to catch such error of "emtpy"
> signature file without crashing.
Given that write_img() will always be called, I suggest making
read_signatures() generate an error if the ClassSig field is NULL
after I_ReadSigSet() returns.
AFAICT, the same issue also applies to the "title" field.
