[GRASS-dev] [GRASS GIS] #971: d.what.vect: doesn't query longitude=180-360
GRASS GIS trac at osgeo.org
Mon Mar 1 01:31:17 EST 2010
 Reporter:  hamish           |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect           |      Status:  new
 Priority:  normal           |   Milestone:  6.4.0
Component:  Vector           |     Version:  svn-releasebranch64
 Keywords:  d.what.vect, LL  |    Platform:  Linux
      Cpu:  x86-32           |
 If I set the region of a world map to center on Australia, d.what.vect
 only gives query results for longitude<180.
 it should automatically convert coords with 180-360 &/or -180-0 to match
 the same standard as the read-map data uses.
 (I expect this goes rather deeper than d.what.vect, and so has a higher
 payoff for fixing..)
 g.region w=25W e=25W res=0:30 -p
 d.rast etopo2
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/971>
