[GRASS-dev] Re: [GRASS GIS] #975: WxGUI should provide area measurement tool
GRASS GIS trac at osgeo.org
Mon Mar 1 20:37:53 EST 2010
  Reporter:  marisn       |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  normal       |   Milestone:  6.4.0
 Component:  wxGUI        |     Version:  unspecified
Resolution:               |    Keywords:  d.measure
  Platform:  All          |         Cpu:  All
Comment (by hamish):
 can swig/python/examples/m.distance.py (or swig in general) be used by the
 core wxgui.py? if so, there is very little left to do. if not I guess we
 need a C version of it.
 even if swig errors can not be caught directly, m.distance.py as a
 separate program probably could be caught when called from wxgui.py. (?)
 same question is true for gui/wxpython/gui_modules/units.py and probably a
 lot of other stuff which should be handled by libgis instead of
 reimplemented from scratch in the GUI code.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/975#comment:5>
