[GRASS-dev] [GRASS GIS] #981: v.external db connection key missing
for some GDAL drivers
trac at osgeo.org
Wed Mar 3 13:39:00 EST 2010
#981: v.external db connection key missing for some GDAL drivers
Reporter: rblazek | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
If OGR_L_GetFIDColumn does not return a column (OGR SHP driver for
example) it is then missing in db connection info and consequently db
operations do not work on vector created using v.external. The problem is
here
http://trac.osgeo.org/grass/browser/grass/trunk/lib/vector/Vlib/field.c#L8
and there is already TODO here
http://trac.osgeo.org/grass/browser/grass/trunk/lib/vector/Vlib/field.c#L582
The problem can be tested either by v.db.connect -p, no key printed or
d.what.vect for example (key field missing in query).
I dont think it can be easily fixed. It would be possible to add OGR FID
to attributes, but OGR SQL engine most probably does not know about FID,
it only works on true attributes (to be verified, maybe FID is available
with some special name).
Radim
Ticket URL: <http://trac.osgeo.org/grass/ticket/981>
