[GRASS-dev] future thematic cartography in GRASS [was: Re: [GRASS
GIS] #974: [Patch] add option to d.vect to make symbol size
proportionate to square root of size_column]
Hamish
hamish_b at yahoo.com
Thu Mar 4 02:26:59 EST 2010
Moritz wrote:
> What is still missing right now is an easy way to display a
> combination of color-classified and proportionately sized
> symbols.
by the way, WRT floating point raster maps there is a control in ps.map's
colortable instruction to show range bands instead of a smooth legend:
Adding the
discrete Y instruction will command the program to
treat the map as a categorical map. In this way the
legend can be created with discrete range bands instead
of a continuous gradient. You must use the r.category
or r.support module to set up the range labels first.
Hamish
