[GRASS-dev] [GRASS GIS] #984: v.out.ogr to MySQL does not work propely
GRASS GIS trac at osgeo.org
Thu Mar 4 11:17:02 EST 2010
 Reporter:  pablotcarreira   |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect           |      Status:  new
 Priority:  normal           |   Milestone:  6.4.0
Component:  Vector           |     Version:  unspecified
 Keywords:  v.out.ogr mysql  |    Platform:  MSWindows XP
      Cpu:  x86-32           |
 With OSGeo4W version
 When try v.out.ogr some vectors to Mysql
 I got the following problem:
 ERROR 1: MySQL error message:Duplicate entry '1' for key 'OGR_FID'
 For every vector it try to use the same OGR_FID and at the end It exports
 only the first vector becouse the other has duplicated FID.
 the command is the following:
 v.out.ogr --verbose input=areas_vector at geral type=area
 dsn=MYSQL:geobase,user=root,password=xxxxx,host=localhost format=MySQL
 olayer=teste3 -c lco=spatial_index=no
 I had sent a message to gdal-devel and here is the answer:
 >>This could happen if you pass to CreateFeature() features that have the
 same
 >>id set by OGRFeature::SetFID() as being 1... Check with
 OGRFeature::GetFID()
 >>what you pass to CreateFeature().
 >>Even
 With ogr2ogr utilitie the GRASS->MySQL works fine.
Ticket URL: <http://trac.osgeo.org/grass/ticket/984>
