[GRASS-dev] Suggestion: wxGUI as default in G6.4
Markus Neteler
neteler at osgeo.org
Fri Mar 5 05:47:25 EST 2010
On Tue, Mar 2, 2010 at 11:53 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Mar 1, 2010 at 4:53 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
>> Markus Neteler wrote:
>>> On Sun, Feb 28, 2010 at 6:10 PM, Glynn Clements
>>> >> (gdb) r /home/neteler/grass64/dist.x86_64-unknown-linux-gnu/etc/wxpython/wxgui.py
>>> >> (gdb) bt
>>> >> #0 mem2chunk_check (mem=0x7f032d40a000, magic_p=0x0) at hooks.c:156
>>> >> #1 0x00007f034d30633c in free_check (mem=0x7f032d40a000,
>>> >> caller=<value optimized out>) at hooks.c:280
>>> >> #2 0x00007f033bde9cf2 in XML_ParserFree () from
>> This looks very suspicious:
>> ==15942== by 0x9043DB4: XML_ParseBuffer (in /usr/lib/wxPython/lib/libwx_gtk2u-2.8.so.0.5.0)
> Ok, SPEC file enriched with --with-expat=sys, recompiled, installed and
> ...MUSIC.... it works!! After 9 months or so wxNVIZ and wxVDIGIT are back
> on my laptop.
> Great job, Glynn.
> Bug report files with the RPM maintainer.
s/files/filed/
The new RPM is in "testing".
The Mandriva maintainer told me:
"I can only push this as an official update if there is a simple
instruction to
for the QA team to reproduce the bug."
Do you have a suggestion to make a simple test case for above problem?
Thanks
Markus
