[GRASS-dev] [GRASS GIS] #985: v.db.update error
GRASS GIS trac at osgeo.org
Fri Mar 5 13:13:48 EST 2010
 Reporter:  fpacheco     |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Python       |     Version:  unspecified
 Keywords:  v.db.update  |    Platform:  All
      Cpu:  Unspecified  |
 v.db.update.py script have error in line 108:
 v.db.update map=prueba_1 at fpacheco colum=j value=100
   File "/usr/local/grass-7.0.svn/scripts/v.db.update", line 124, in
 <module>
     main()
   File "/usr/local/grass-7.0.svn/scripts/v.db.update", line 108, in main
     if coltype.upper() not in ["INTEGER", "DOUBLE PRECISION"]:
 AttributeError: 'dict' object has no attribute 'upper'
 Solution:
 Replace
 by
 if coltype['type'].upper() not in ["INTEGER", "DOUBLE PRECISION"]:
Ticket URL: <http://trac.osgeo.org/grass/ticket/985>
