[GRASS-dev] Re: [GRASS GIS] #986: WinGrass-Installer - Enhancement
trac at osgeo.org
Sat Mar 6 03:48:42 EST 2010
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.0
Component: Installation | Version: svn-develbranch6
Resolution: | Keywords: wingrass
Platform: MSWindows Vista | Cpu: Unspecified
Comment (by hellik):
Replying to [comment:4 hamish]:
> Replying to [comment:3 hellik]:
> > i would change ''RequestExecutionLevel user'' to
> > ''RequestExecutionLevel admin'' for the installer set by
> > the NSIS-script.
> would it still be possible to install to your home directory in that
case? ie can you say no to the request and still manage to install it?
> thanks,
> Hamish
with ''RequestExecutionLevel admin'' by '''double click''' (no right
click) on the Win-installer a Windows-message-box asks you if you want
continue or not and, if you continue, you are granted admin rights to
install in c:\Program Files\ or whereever you want.
with ''RequestExecutionLevel user'' you have to '''right click''' and
''run as admin'', then the same Windows-message-box described above pops
up and, if you continue, you are granted admin rights to install in
with ''RequestExecutionLevel user'' and '''only double click''', you can
continue with the installer, but installing and extracting files in
c:\Program Files\ fails on the most WinVista/Win7-boxes, also creating
desktop shortcuts etc may fail. installing in c:\ may be possible, depends
on what rights the sysadmin gives to you. installing in other drives like
d:\ etc may be possible. installing in your windows-home-directory should
be possible.
so there are a lot of different options of granting installations rights
in the windows world, AFAIK there have to be at least one user interaction
to get installation rights in c:\Program Files\.
IMHO interaction with ''RequestExecutionLevel admin'' and '''double
click''' for starting the installer should be the easiest one.
with ''RequestExecutionLevel user'' and '''right click''', there should be
anywhere an information about this (installation-README, installer-pop up
with a message about this, ...).
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/986#comment:5>
