[GRASS-dev] Re: [GRASS GIS] #987: Location wizard choose from EPSG
robustness issues
trac at osgeo.org
Sun Mar 7 12:37:36 EST 2010
#987: Location wizard choose from EPSG robustness issues
Reporter: marisn | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: svn-releasebranch64
Resolution: | Keywords: location wizard
Platform: Linux | Cpu: Unspecified
Comment (by marisn):
That's much better.
Still search should not be performed if proper file is not selected:
File "/home/maris/soft/grass_64/dist.x86_64-unknown-linux-
gnu/etc/wxpython/gui_modules/location_wizard.py", line 1437, in OnSearch
self.epsglist.Search(index=[0,1,2], pattern=value)
ValueError: need more than 0 values to unpack
Also currently EPSG file change is detected only after browse or on ENTER.
It would be nice to detect simple edits without need to press ENTER.
Following approach has one disadvantage - if file name field has focus
when user chooses CANCEL, it also gives an warning about improper file
name if it's wrong one. As I have no idea how events work in wxpython, I
can't provide code, just an idea.
Index: wxpython/gui_modules/location_wizard.py
--- wxpython/gui_modules/location_wizard.py (revision 41318)
+++ wxpython/gui_modules/location_wizard.py (working copy)
@@ -1350,6 +1350,7 @@
# events
self.bbrowse.Bind(wx.EVT_BUTTON, self.OnBrowse)
self.tfile.Bind(wx.EVT_TEXT_ENTER, self.OnBrowseCodes)
+ self.tfile.Bind(wx.EVT_KILL_FOCUS, self.OnBrowseCodes)
self.tcode.Bind(wx.EVT_TEXT, self.OnText)
self.tcode.Bind(wx.EVT_TEXT_ENTER, self.OnText)
self.epsglist.Bind(wx.EVT_LIST_ITEM_SELECTED,
self.OnItemSelected)
@@ -1368,6 +1369,7 @@
# load default epsg database file
self.OnBrowseCodes(None)
+ self.searchb.SetFocus()
event.Skip()
Ticket URL: <http://trac.osgeo.org/grass/ticket/987#comment:2>
