[GRASS-dev] Re: [GRASS GIS] #111: r.los fails with high values for max_dis parameter
GRASS GIS trac at osgeo.org
Sun Mar 7 15:16:37 EST 2010
  Reporter:  gsancho       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  Raster        |     Version:  svn-develbranch6
Resolution:                |    Keywords:  wingrass r.los
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hellik):
 Replying to [comment:32 pcav]:
 > Here it is (available for a while):
 > http://int.faunalia.it/~paolo/Toscana_rlos.tar.gz
 > Tested again with the command
 > r.los input=dtm at PERMANENT coordinate=1676734,4831167 obs_elev=100
 max_dist=10000 output=rlos
 > and it fails
 tested it with an actual self compiled grass64 and grass65 on WinVista32,
 r.los works in both versions.
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/111#comment:35>
