[GRASS-dev] grass 6.4.0rc6
Helmut Kudrnovsky
hellik at web.de
Sun Mar 7 16:09:24 EST 2010
>Just to note, the Linux install script (binaryInstall.src) runs
>g.mkfontcap outside of a GRASS session by simply setting GISRC to a junk
>value:
>GISBASE="$DESTDIR" GISRC=junk LD_LIBRARY_PATH_VAR="${DESTDIR}/lib:$LD_LIBRARY_PATH_VAR" "${DESTDIR}/bin/g.mkfontcap" -o
>(In Windows the equivalent would be to run the command
>set GISRC=junk
>before running g.mkfontcap)
>Not 100% sure if that's relevant here, but thought it might be worth
>mentioning to give some context.
>Paul
thanks for your hints.
the changes in g.mkfontcap a very small (see http://lists.osgeo.org/pipermail/grass-commit/2010-March/012283.html).
anyway for the windows-installer there's some bat-file needed,
because AFAIK the NSIS-scripting language used for the wingrass-installer can't set variables like GISBASE
and the path to the freetype-library before executing an exe.
best regards
Helmut
___________________________________________________________
GRATIS für alle WEB.DE-Nutzer: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://movieflat.web.de
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20100307/67222d9b/smime.bin
