[GRASS-dev] [GRASS GIS] #989: wx georectify: implement best features of i.points
GRASS GIS trac at osgeo.org
Mon Mar 8 09:45:09 EST 2010
 Reporter:  hamish                |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement           |      Status:  new
 Priority:  normal                |   Milestone:  6.5.0
Component:  wxGUI                 |     Version:  svn-develbranch6
 Keywords:  georectify i.rectify  |    Platform:  All
      Cpu:  All                   |
 wishes from #728:
     * would it be possible to change the color of GCP lines which are 1
 standard dev. out from the mean GCP error as orange and 2 S.D. out as red?
 that is a nice way in i.points to see where your typos are. Or failing
 that, allow sort rows by clicking on column so you could group the worst
 offenders to the top.
     * is it possible to bind the arrow keys to move the currently selected
 GCP 1 pixel on the map display window?
     * more i.points goodness: can you change the color of the map marker
 to orange if that is the currently selected GCP data row? and have it
 still display on the map but turn to red if it the Use box is unticked?
     * long shot wish: i.vpoints lets you select a vector map from the
 target mapset to overlay on the fly based on the current tansform
 calculation. The other nice thing it has is left and right panels, in the
 left one you click on a feature in the source image, and in the right you
 click on what you know to be the same point in another map (rast or vect)
 in the target location. It then uses the x,y from the left pane and the
 east,north from the right pane to create the GCP without having to know or
 type any coords.
     * from there is the grass5 addon magic auto GCP image tool, but one
 (or 5) things at a time :)
 thanks, Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/989>
