[GRASS-dev] [GRASS GIS] #991: v.out.gpsbabel export fails with layer=2
GRASS GIS trac at osgeo.org
Mon Mar 8 15:54:20 EST 2010
 Reporter:  needelsd        |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect          |      Status:  new
 Priority:  normal          |   Milestone:  6.4.0
Component:  Translations    |     Version:  6.4.0 RCs
 Keywords:  GPS GPX export  |    Platform:  Unspecified
      Cpu:  Unspecified     |
 It appears that v.out.gpsbabel fails when used with the layer=2 option.
 I am running William Kyngesburye's 6.4RC5-3 on Mac OS X Leopard.
 [A] All exports using v.out.gpsbabel generate the following error, even
 when the exports seem to have worked correctly.
 /Applications/GRASS-6.4.app/Contents/MacOS/scripts/m.proj: line 197: [: :
 integer expression expected
 Spearfish example:
 v.out.gpsbabel -w input=bugsites type=point output=bugsites.gpx
 [B] With several exports using layer=2 (including data generated from
 v.to.points), v.out.gpsbabel fails with the following message (this one is
 from a WGS84 lat/lon location).
 ERROR: Error reading categories: [ 2.00000000 1.00000000 0.00000000]
 ERROR: Error reprojecting data
 Spearfish example:
 v.category input=bugsites output=bugsites_two option=add layer=2
 v.out.gpsbabel -w input=bugsites_two type=point output=bugsites_two.gpx
 ERROR: Error reading categories: [ -109.48867688 0.00000902 0.00000000]
Ticket URL: <http://trac.osgeo.org/grass/ticket/991>
