[GRASS-dev] [GRASS GIS] #998: v.colors color column selection bug - default GRASSRGB not show in dialog
GRASS GIS trac at osgeo.org
Sat Mar 13 04:14:48 EST 2010
 Reporter:  neteler      |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.0
Component:  wxGUI        |     Version:  svn-releasebranch64
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 When using v.colors via wxGUI, the default GRASSRGB is not show in the
 dialog
 but instead all existing table columns (see screenshot).
 v.colors
 #%Option
 #% key: rgb_column
 #% type: string
 #% required: no
 #% description: Name of color column to populate
 #% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
 #% answer: GRASSRGB
 #% guisection: Colors
 #%End
 In d.vect, the column selector in the "Colors" tab is deactivated (also
 confusing).
 For all such color column selectors, the "GRASSRGB" should be predefined
 and be the first choice in the color column selector.
Ticket URL: <http://trac.osgeo.org/grass/ticket/998>
