[GRASS-dev] Are such construction/declaration allowed for GRASS ??
Jarek Jasiewicz
jarekj at amu.edu.pl
Sat Mar 13 05:40:20 EST 2010
Glynn Clements pisze:
> Jarosław Jasiewicz wrote:
>> Can I use in module prepared for GRASS such constructions:
>> typedef enum {
>> AND, /* & */
>> OR, /* | */
>> NOT, /* ~ */
>> IS, /* = */
>> THEN, /* : */
>> LBRC, /* ( */
>> RBRC, /* ) */
>> START, /* { */
>> STOP, /* } */
>> MAP, /* mapname */
>> VAR, /* variable name */
>> size /* number of tokens */
>> } tokens;
>> char parseTab [size][size] = { /* parser table definition is here */
>> I mean type enum and enum size variable to initialize table. It compiles
>> on gcc 4.3 but, as I know GRASS has restriction and I'm not sure if such
>> is fully allowed.
> In general, if it's valid C89 (use "gcc -std=c89 ..." to check), then
> it's fine. Any use of gcc extensions or C99-specific features must be
> conditional, with a fallback if those features aren't available.
> Similarly, use of functions which aren't specified by C89 should be
> conditionalised (non-C89 functions which are specified by POSIX are
> okay provided that they're available on Linux, Windows and MacOSX).
Ok, thanks Glynn. It means I shoud be OK, but I didn't find typedef enum
... in any fo GRASS code, so I asked.
Jarek.
