[GRASS-dev] WinGrass7 - disable LFS
Sun Mar 14 03:10:19 EDT 2010
Helmut Kudrnovsky wrote:
> >Has disabling LFS to be set explicitly for configure in the windows-world?
> I've tried --disable-largefile,
> but again there is
> checking if system supports Large Files at all... yes
> Large File support (LFS):   yes
> in the build-log.
> what have to be done to disable LFS for building WinGrass7?
configure.in is broken; it sets USE_LARGEFILES according to whether
LFS is detected, regardless of whether it is enabled. MinGW has LFS,
but it's not in a form which currently works with GRASS.
