[GRASS-dev] Re: [GRASS GIS] #1001: Add option to replace (instead of just add) cats with v.category
GRASS GIS trac at osgeo.org
Sun Mar 14 09:45:13 EDT 2010
  Reporter:  needelsd     |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  normal       |   Milestone:  6.4.0
 Component:  Vector       |     Version:  6.4.0 RCs
Resolution:               |    Keywords:  v.category add del replace cats
  Platform:  Unspecified  |         Cpu:  Unspecified
Old description:
> Add an option to v.category option=replace that overwrites the cat values
> in a vector instead of only adding a cat to objects that do not already
> have a cat.
> Equivalent to
> v.category input=input_vector output=tmp option=del
> v.category input=tmp output=output_vector option=add
> g.remove vect=tmp
> Personally, I would also appreciate a flag [-r]?? or other mechanism to
> overwrite cats in the original vector (allow output=input).
New description:
 have a cat.
 Equivalent to
 g.remove vect=tmp
Ticket URL: <http://trac.osgeo.org/grass/ticket/1001#comment:2>
