[GRASS-dev] [GRASS GIS] #1006: r.terraflow fails to create temp
file on Windows when launched from wxgui
trac at osgeo.org
Sun Mar 14 13:06:20 EDT 2010
#1006: r.terraflow fails to create temp file on Windows when launched from wxgui
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Keywords: wxgui, wingrass, terraflow | Platform: MSWindows Vista
Cpu: x86-32 |
Temporary file folder (specified as STREAM_DIR) exists and is writeable
for current user.
Run r.terraflow with default STREAM_DIR option within wxgui:
Sun Mar 14 18:47:32 2010)
r.terraflow elevation=reljefs_rst_t100 at zonde filled=floddeed
direction=dirrectionss swatershed=sinkss accumulation=akumulacija2
tci=tcii
stats.out: Permission denied
STREAM temporary files in C:/Users/Maris/AppData/Local/Temp
(THESE INTERMEDIATE STREAMS WILL NOT BE DELETED IN CASE OF
ABNORMAL TERMINATION OF THE PROGRAM. TO SAVE SPACE PLEASE
DELETE THESE FILES MANUALLY!)
(Sun Mar 14 18:47:32 2010) Command finished (0 sec)
Running the same from CLI:
GRASS 6.4.0svn (latvija3)> r.terraflow elevation=reljefs_rst_t100
filled=fffllll
l direction=diiiirrr swatershed=siiiknk accumulation=aacccum tci=tttopoc
STREAM temporary files in C:/Users/Maris/AppData/Local/Temp (THESE
INTERMEDIATE
STREAMS WILL NOT BE DELETED IN CASE OF ABNORMAL TERMINATION OF THE
PROGRAM. TO
SAVE SPACE PLEASE DELETE THESE FILES MANUALLY!)
MFD flow direction
D8CUT=999999986991104.000000
Memory size: 300.00M (314572800) bytes
Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
Assertion failed: nrows * ncols == str->stream_len(), file grass2str.h,
line 144
This application has requested the Runtime to terminate it in an unusual
way.
Please contact the application's support team for more information.
WinGRASS-6.4.SVN-r41428 on Windows Vista
Ticket URL: <http://trac.osgeo.org/grass/ticket/1006>
