[GRASS-dev] Location wizard (missed window to select +towgs params)
Paul Kelly paul-grass at stjohnspoint.co.uk
Sun Mar 14 13:22:51 EDT 2010
Hello all,
I have a little more insight on this. See below.
On Fri, 12 Mar 2010, Paul Kelly wrote:
> On Fri, 12 Mar 2010, Markus Neteler wrote:
>> On Fri, Mar 12, 2010 at 8:38 PM, Martin Landa <landa.martin at gmail.com>
>> wrote:
>>> Hi,
>>> 2010/3/12 Massimo Di Stefano <massimodisasha at gmail.com>:
>>>>  "location wizard -> select epsg code -> search for : 3004"
>>>> in the paste release (build less than 1 month ago) after select the
>>>> epsg:code(3004)
>>>> grass prompt me to the window :
>>>> http://img534.imageshack.us/img534/8254/schermata20100312a09564.png
>>>> to select the +towgs parameters
>>>> with the latest svn version this window doesn't appair and  the locaqtion
>>>> is created using the default parameters :
This is not correct, and indeed seems to be a clue as to what is going on.
The GRASS default parameters for rome40/Monte_Mario are
+towgs84=-225.000,-65.000,9.000
However the location is being created with the parameters
+towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
i.e. the parameters with the description "Used in Italy (Peninsular Part)"
from datumtransform.table.
This set of parameters is not being put there by GRASS; it is coming
through from GDAL when it is used to look up the EPSG code.
>>> it seems to be bug in g.proj -
>>> g.proj epsg=3004 datum=-1
>>> no output is printed...
>> When you add -t, it works:
>> g.proj epsg=3004 datum=-1 -t
> The fact that the -t flag needs to be specified, suggests that somehow when
> g.proj is querying GDAL for a projection description for EPSG code 3004, it
> is coming back fully specified, i.e. with complete towgs84 parameters, and
> thus g.proj thinks the datum information is already all specified and
> correct, so it doesn't even offer the option of modifying it unless the user
> requests to override the datum information in the input co-ordinate system
> with the -t flag. (I'm sure there is a logical reason for working like that
> although it doesn't immediately come to mind at the minute!)
This is true, and as there have been very minimal changes in
general/g.proj and lib/proj between RC5 and now I was initially very
baffled. My latest hunch is to do with the CSV tables in lib/proj. I
notice Markus has updated them at least a couple of times since RC5 - the
latest change two weeks ago in r41248 with the description "backport from
GDAL: big upgrade to EPSG 7.4.1 with improved datum logic" sounds
particularly suspicious ;) I would hazard a guess that GDAL is now
attempting to make a "best guess" at which are the most appropriate
transformation parameters for a particular datum. Previously if there was
a choice it left them unspecified, and GRASS prompted the user. However
GRASS (i.e. g.proj) trusts the co-ordinate system it gets back from GDAL
and if the datum transformation parameters are already there, then it
doesn't query GDAL's decision! I don't subscribe to the GDAL developers
list any more as there was too much traffic, so it's likely I've missed
some discussion or announcement from Frank over there.
I haven't had time to test reverting the CSV files yet but if that works I
would suggest doing it, as if that is going to be the way GDAL works from
now on it will require quite a few changes to how g.proj works, and it is
much too late in the release cycle of 6.4.0 to go changing things there...
More later
Paul
