[GRASS-dev] Re: [GRASS GIS] #995: WxGUI startup screen fails if
GISDBASE path contains non-latin characters
trac at osgeo.org
Sun Mar 14 14:32:27 EDT 2010
#995: WxGUI startup screen fails if GISDBASE path contains non-latin characters
Reporter: marisn | Owner: martinl
Type: defect | Status: assigned
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: svn-releasebranch64
Resolution: | Keywords: wingrass, i18n
Platform: MSWindows Vista | Cpu: Unspecified
Comment (by marisn):
Location Wizard still fails in Windows Vista WinGRASS-6.4.SVN-r41428-1:
C:\Program Files\GRASS-64-
SVN\etc\wxpython\gui_modules\location_wizard.py:2002:
UnicodeWarning: Unicode unequal comparison failed to convert both
arguments to U
nicode - interpreting them as being unequal
if current_gdb != database:
File "C:/Program Files/GRASS-64-SVN/etc/wxpython/gis_set.py", line 418,
in OnW
izard
grassdatabase = self.tgisdbase.GetValue())
File "C:\Program Files\GRASS-64-
y", line 1853, in __init__
msg = self.OnWizFinished()
y", line 2011, in OnWizFinished
set='GISDBASE=%s' % database)
File "C:\Program Files\GRASS-64-SVN\etc\wxpython\gui_modules\gcmd.py",
line 60
8, in RunCommand
ps = grass.start_command(prog, flags, overwrite, quiet, verbose,
**kwargs)
File "c:/osgeo4w/usr/src/grass64_release/dist.i686-pc-
mingw32\etc\python\grass
\script\core.py", line 145, in start_command
\script\core.py", line 52, in __init__
File "C:\Program Files\GRASS-64-SVN\Python25\lib\subprocess.py", line
594, in
__init__
errread, errwrite)
816, in
_execute_child
startupinfo)
UnicodeEncodeError: 'ascii' codec can't encode character u'\u0160' in
position 7
9: ordinal not in range(128)
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:7>
